Hey guys and gals!
I've been wanting to get to doing my brake discs and pads for a while now, I know I don't have the funds to do them yet but while it's still fresh in my mind I wanted to get some recommendations and also some clarification!
I believe that my front brake discs are 280mm by 22mm thick, though there are the possibility of it being 256mm by 22mm thick? Rears being either 232mm or 256mm (again not 100% sure) only way I can know for sure what is on mine properly is to measure both front and back respectively.
So, what I would like to know is when I find out the right discs to fit to my car, what types would you suggest and why? Solid, grooved or drilled and grooved? I don't personally want to have the drilled type due to reading about them being able to split/crack quite easily, so the drilled option would be out of it for myself.
Any particular pad type? I was going to go down the route of Pagid for the time being but with me knowing next to nothing I'd rather get some recommendations, just for the topic I want to stay around the OEM style, I'm not uprating the brakes or anything like the calipers or going bigger sized discs just yet, I don't want to go down that route until it's time for a remap and the funds are there!
I've taken a look at this thread, that guide should be spot on for doing my brakes right? If not are there any particular tips or tools I'd need to have on hand before attempting this?
Hopefully I've put enough information here, if not let me know what I'm missing and I'll try to include more
Thanks in advance!
--Lee
Thanks in advance!
--Lee
