As above, Is it worth me getting drilled a grooved discs ? or just drilled / grooved? standard type discs good enough? if so / not which set-up should I go for?
Also what size are my brake discs ? i've read the face-lift LC brakes were larger? mine was a late pre-face lift with a facelift LC kit, will I be able to use the larger brake discs / pads?
I've seen some really well priced brake discs on eBay for mk4 golfs, drilled and grooved, would mk4 golf Gti discs fit?
