No, Read ALL of this before having another go.
What you will have to do is take the Pads out and clean then off by rubbing them over 40 or 60 grit rubbing down paper ON A FLAT SURFACE to clean off any residue, don't forget to wear a mask when doing this. It'll only take a few minutes for each one and you'll see when they are clean.
While you've got them out see if the calipers move forward and back on the sliding posts, they will be a little stiff but, if they don't move unless you put a lot of pressure on them then they could be corroded up.
To get at them if this is the case remove the round rubber plug at the top and bottom on the inner side of the caliper, you will see a hexagon shape allen bolt inside which I think is 10 millimetres in size. Undo one at a time and pull it right out, if it is corroded then clean it up with 320 grit wet and dry paper and cover it thinly in copaslip NOT grease
( Copaslip will stand the high temperatures of braking, grease won't Don't get it on the discs if you do clean it off thoroughly with disc cleaner )
Clean out the hole it came out of in the caliper as well with new same grit paper, in the middle is a rubber seal which grips the slider so don't overdo it.
Use fresh 320 grit paper on the two faces of the discs and then clean off with disc cleaner on a rag. Paint Thinners can be used BUT will stink like heaven but it won't leave a residue on the discs either, it is HIGHLY flammable so don't smoke around it or have any heat source near it.
As with anything on a braking system....be clean and be methodical check twice if necessary.
Don't forget the only thing worse than not going is NOT STOPPING.
