Chrismh
Is the brake calibers the same size at a Leon 1.9 TDI Eco as on a FR TDI model.
I would like to have switched to larger discs and brake pads, if possible..
i have a tdi sport 140 with 288 discs which uses the same caliper as fr, but fr has 312mm discs and a different caliper carrier to take larger disc, i belive some leons have 280mm discs which use a different caliper
Yes, as confirmed above - The FR does come as standard with larger Brake Discs/Calipers (312mm), than non 'FR' Mk2 Leons for comparison.
