what are the current brakes? original or aftermarket? what brand? If you have some cheap aftermarket pads - then fitting a decent set of pads will be beneficial.
What are you expecting to 'upgrade' in regards to your braking performance?
Deceleration/wear/fade resistance/noise/dust etc..
If you are looking at reduce your stopping distance (increasing your decel) - The standard (correctly functioning) brakes will be able activate your ABS so you should first fit decent tyres as the brakes aren't the limiting factor.
The main reason to fit bigger brakes (like the 370mm performance pack Brembo's) would be for improved fade resistance - for repeated high & speed heavy braking, like on track. They would also give you a better/firmer pedal feel.
I would be honest with your usage vs the cost of any change.
Cheapest will be just fit new pads and discs - selecting decent pads with good high temp performance. Avoid pads made by brake system manufactures - look for pads made my friction manufactures.[mention]SuperV8 [/mention] I’ve got the current brakes, I’m not sure on the pads I brought the car second hand from a dealer.
I noticed a slight squeak when I brake, so thought I would look at upgrading my setup at the main time.
Looking for good fade resistance and also better stopping capability.
Jeps, all stock brakes are sufficient. There are laws for this. Once you look at brakes as heatsinks, it starts to make sense.
Driving 4 Answers has some good videos about it
Just to add to the above comment check out https://www.tyrereviews.com/Tyre-Tests/2025-Auto-Bild-Summer-Performance-Tyre-Test.htm which was listed on another thread on here, Pictures should explain about tyres ability to stop youIf you are looking at reduce your stopping distance (increasing your decel) - The standard (correctly functioning) brakes will be able activate your ABS so you should first fit decent tyres as the brakes aren't the limiting factor.
