BTCC LED running lights
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
I'll get the multi-meter out at the weekend and see what works best. The strange thing is that if you don't start the engine the lights go off after about 10 seconds but once the engine has started they stay on for about 10 mins.
Will update once I've had a go!
Might that be the fuse for the auxiliary coolant pump? Dunno...
I'm sure ELSA has a wiring diagram...I'll give that a peek tomorrow. Has all the fuses and stuff
manhota
275
west mids wolves area
Jun 24, 2011
1,137
Sheffield
I got the last 5 sets of bulbs from that seller, sorry :) It seems all his relisted bulbs are now at stupid prices, I'm just going to make it work with 10 bulbs instead of 12.
shnazzle
Sep 9, 2011
3,480
Northumberland
That would be good of you can!
hmmm...
F22 - SB22 - Fuse 22 on fuse holder 5A - G476- Clutch position sender 87
Clutch position sender? how odd....
and that's only on a manual. So I'm guessing it'll be empty on the DSG?
In any case, I have no clue why that would stay on for 10 minutes.
coolant pump was F20, so that's not it. I'm well confused.
Faceless
254
Photos:
Side view at night.
Excellent guide, plus the finished look at night is quite stunning. lol.
I'm transformed :D - wasnt into DRL's that much before, all looked the same.
The above side shot at night does it for me. :)
Jun 24, 2011
1,137
Sheffield
The seller who sells the glass disks for the DRL's has run out, they are going to let me know as soon as they get some more.
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,303
7
Desborough
Bloody heck. Right guys, can we have one post with links to all the bits required? I need to order this stuff tonight hahahahha
robthebubble
LED & Headlight Master
Feb 22, 2011
1,442
Solihull, West Midlands
SMD: http://www.ebay.co.uk/itm/2x-ERROR-...arts_Vehicles_CarParts_SM&hash=item43af838ebe
Fuse Holder: http://www.ebay.co.uk/itm/Add-A-Cir...9?pt=UK_In_Car_Technology&hash=item2a14ad475d
Glass lens: http://www.ebay.co.uk/itm/Clear-Gla...s_JewelleryMaking_GL&var=&hash=item2a1c69422f
I'm sure you can get to screwfix and get the silicone sealant and cable from there/have some in the garage! :D
robthebubble
Feb 22, 2011
1,442
hmmm...
I know...it's a strange one but I'll have a look over the weekend and update everyone if I can fine a better source for the fuse.
jc_boc
Jul 18, 2008
9,303
7
Desborough
robthebubble
Feb 22, 2011
1,442
I believe canbus is not required for this to work as its not using power from the current light setup of the car its direct from the fuse box + and - from the chassis.
so below might help u
http://www.ebay.co.uk/itm/10-x-T10-...arts_Vehicles_CarParts_SM&hash=item3373d195c2
http://www.ebay.co.uk/itm/2x-1-LED-...arts_Vehicles_CarParts_SM&hash=item2c63955c01
http://www.ebay.co.uk/itm/2-PCS-T10...arts_Vehicles_CarParts_SM&hash=item53ecc55ffe
I think you're right and out of all of these I'd go with the top ones however they are 12mm and I measured that 10mm is the max to fit in the second hole down on the vent. Probably wouldn't need the glass covers with these either but I think for an MOT you need aglass lens?!?!?
robthebubble
Feb 22, 2011
1,442
