Buzzing noise!!!
jonocupra
hey, just parked my car up earlier and noticed a buzzing noise comming from front of engine (sounds like some sort of pump?)even when the car is turned off and locked up. it stops after about 5 mins but does it everytime the ignition has been turned on then off. just wonderin if this is normal of does summin sound F****d?
R0b
104
Water pump is still pumping water round engine and what not to cool it down.
I wondered this when i first got mine
Oct 17, 2006
893
Walthamstow
I think its near the driver's side headlight, just behind it is a metal cylinder... thats where the noise was coming from for me - i just assume it was engine cooling related.
R0b
104
Sounds about right my friend, my noise is located in the same place
dolf
The Dolf
Aug 14, 2006
68
cheshire
has anyone else's pump failed?
Mine was replaced under warranty just under 2 years ago but is now on its way out again. Can hear it grinding and spluttering for a few seconds after you switch off, then it runs ok.
A few quid to replace i believe.
