Leonfrdiesel184
159
37
Hi everyone I just wondered if someone could give me the right direction for the correct water pump and cambelt kit for my car it's the 2018 cuna 2.0 TDI 184 5f1 engine.
The coolant needs changing but is there anything else whilst doing this I should get done ?
Thanks so much to anyone who can help
If you need part numbers, I can look that up for you, using your VIN. Send it over via a private message and I'll get back with part numbers.
Check your front crank oil seal - if weeping/leaking ideal to change it when doing the cam belt.
I also changed my thermostat "whilst I was in there"
New aux belt - and check your tensioner.
