Status
Not open for further replies.
Thought you said all cars did it that way? Seemed very confident about that, listing all the ones you owned.
So once again. I have 3 MIB2s on the table and 3 MIB2s installed in cars. None of them have this seek mode from the factory. No matter which manual I look at, no matter which MIB2 system, strangely enough the seek mode is never mentioned. Then someone says that's their photo and shows a cropped photo with a hardware number. Either the English have a different firmware, or it was coded, in this case it would be news to me.
It would also be news to me that it had a full glass display before the facelift.
  • Haha
Reactions: El Spavo
It's not a cropped photo that's how I took it! Close up
Full glass display 8 inch screen mib2
My Mib1 2014 leon also acts the same in that pressing the steering wheel buttons changes to the next preset
But it can't be mate! It's been proven on here that every vag car ever since 2010 doesn't do it.
Please stop lying stu, it makes the baby jesus cry!
Reactions: stu_m
Es ist kein zugeschnittenes Foto, so habe ich es aufgenommen! Nahaufnahme
Vollglasdisplay 8 Zoll Bildschirm mib2
Mein Mib1 2014 Leon verhält sich auch so, dass das Drücken der Lenkradtasten zur nächsten Voreinstellung wechselt
Dies im Bild sind Ihre DAB-Einstellungen.
Hey, captain arrogant, despite you talking sh1te and thanks to stu I found the setting to change it on my 2017 mib2 and it works fine now. Feel free to crawl back under your stone.
Thanks stu, top man.
Its been a while, I absolutely and totally forgot how many bellend keyboard warriors you get on car forums. ?
Reactions: stu_m
This is only a DAB Setting. No DAB Unit No Setting.
So i can Not have this Setting
Yeah, we've all worked out you haven't got a clue what you're on about mate.
You've just made yourself look a moron, so I'd stop while you're ahead. ?
I have no problem with it. Without a DAB unit, this setting is not available.
why don't you read your car's manual?
Why don't YOU read your car's manual?
Yes, this is from the SEAT website, same as yours.
of course it's normal. 3 Seat Leon 5Fs, a Seat Ateca, an Octavia 3 before facelift, an Octavia 3 facelift, should I keep listing?
You can Not Change the function of the Button.
Sorry, it is possible, when you write a New Firmware in the lin Controller of the Buttons.
sorry, but if you say that it doesn't work, it says so in the instructions, apparently you can't use Google to download the English instructions for your vehicle yourself. But I did it for you. ?
Obviously it IS possible, you arrogant idiot.
Now go away and bother other people instead, you ill informed biff. I'm aware this isn't the first time you've been found out to talk utter sh1te.
I suspect you're still going to reply to this as if you're still somehow right aren't you. ?
DAB Settings
No DAB No Setting
  • Haha
Reactions: El Spavo
I trust we are all being civilised on this thread else I'll have to start sending warnings. Seems a variation on whether the units got DAB or not. I don't trust Seat manuals sometimes describe functionality that isn't in the car.
The beauty of presets you don't have to click through lots of stations you don't want to listen to ?. I can see if you had a few close to each other it's easier to go up and down or just decide all of these stations are rubbish except the news ones perhaps or classical and put them on the presets. Showing my age. Flac music collections does me between the news and we have to watch out we don't listen to the Archers by accident. Only the omnibus, every day story of farming folk or not for those not in the UK.
There are assorted posts and guidance of getting your music collection on SD or USB. That aforementioned manual tells you the directory limits and filename length. Images have to be no greater than 512x512... can get slightly bigger. If embedded in a file and they are too "big" it will cause the mib2 standard to reboot. Memory overflow. Took a while for me to identify what was going on, on that. Somebody had copied a home brew mp3 or flac on the SD card with a large image embedded. The album art. Broken my rigorous home music standard without telling me. All Spotify now so only use that in the car.
Mib contains a media server type of spec which you find on home dnla systems. So you save the music by artist, by album. Within the album directory have one jpeg (512x512) called say cover.jpg. Then they can be accessed either via file view or via the tags. Those tags you set up yourself if digitising your own music files otherwise they are commercially written onto the files. Those embedded graphics which had caused the problem.
Where people go wrong with mp3s is having them all in one directory which blows the spec as per the manual. You'll read on the site cunning plans to separate them into directories. Mp3tag programs are used to hack the tags around. One of those I used to remove the embedded graphic file that was causing the reboot as the unit crashed out. That was a mib2 standard.
BTW there will be more DAB stations once the BBC gets the go ahead to broadcast their Internet only variations you see on BBC Sounds via DAB+. More choice for people that want to go up and down the DAB station list whilst driving...
Status
