Car cutting out and losing power
f17th
was a 1999 2.0 8v gti
Aug 13, 2006
49
West Sussex
Heya Guys
Im looking for a bit of technical help.
My car has been cutting out randomly while driving along.
I drive a Ibiza Mk2 1999 2.0L 8V
I have taken peoples advice and done the following:
Replaced ECU Relay
Replace Fuel Relay
Cleaned Throttle Body
New Dizzy Cap
New Rotor Arm
New Plugs
New Leads
New Ignition Coil Pack
But the problem hasnt gone away and its very intermittant as it might not happen for days or weeks,
while driving along the road the car will just cut out at random, Sometime the car stalls or the Rev's will drop dramatically then bounce back up.
Each time this happens i notice a clicking noise coming from the steering column, Fuse box area.
Ill try and explain the sound.
if you turn the ignition on in the car (so all lights come on the dash)
Turn the key back to the off position but if you leave it there and listen about 5 - 10 seconds or so you will hear a little click.
Im imagining this could be an imobiliser cutting in or fuel pump being turned off or something like that.
But if anyone has any information that could help i would be most appreciative.
Gav
paul6782
hi, this a fault i have had a few times now,and the one thing you have not changed is the engine speed sensor(G28), do you have an engine no of agg??
hope this helps.
f17th
Aug 13, 2006
49
West Sussex
Oh right cheers for the advice,
Is there any way to test the fuel pump or speed sensor for faults ?
Could it just be the filter clogged up with some dirt or something ?
cheers
funboy.ch
83
Switzerland
yo I am having the exact same thing happening with my Ibiza 1.4L 2004. Lately it has been happening more but when I had it at the dealer for a week it never happened and they returned it to me because they didn't find any problems. Is there an update to this problem???
thegills
Also having this exact same problem on my Ibiza mk2 1999 can be coming to a junction and i lose the power asif it stalling :shrug:
dazzlerman
Hi, my Cordoba does exactly the same things as you guys...
Don't supposed anyone has worked out how to fix it yet have you?
monkeybreath
Hi you dont say if it happens in damp or dry weather or when the car is hot or cold as there are a number of things this could be. Sounds like some of you are spending quite a bit of wonger try to "guess" the problem
