Car not starting.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Just been out to give it a try to see if it was water and it's now dried out.
Still not starting but the clicking seemed to have calmed down at the first attempt but returned on the second...
All the noise is coming from the engine bay and not the actual relays.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
the clicking really sounds like your starter motor as said earlier...it is also supposed to die off after holding the key turned.....
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Battery connections all spot on. Just checked, the dash lights come on but when the clunking is going on in the engine bay the battery light flashes. None of them dim.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
With that in mind baz it does point to the starter motor mate. It might be siezed which would stop it jump starting, i can imagine its about £100 for a new one so not to bad really, could be alot worse
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
you have to realize that a car battery loses power quickly if the car won;t start and you keep trying over and over again. Best bet if you are gonna continue trying, to put it on one of those socket loaders, or else you'll be stuck with a dead battery soon.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
but myki if it is the starter motor he might as well try and give it a good wack first with a heavy blunt object and see if it starts then...that will rule it out for sure
Dec 3, 2007
2,475
cardiff
tried!
Process of elimination.
Have fuel? Check injectors and pump
Have spark? Take plugs out and try.
Ecu?
Fuses?
Relays?
Temp sensor?
Vagcom again?
Dec 3, 2007
2,475
cardiff
i know you say you have tried jumping it. But if the battery is cream crackered then jumping it wont work. Get another battery on it just to try
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Right lads everybody that said something to do with starter motor was correct. The connector was all corroded. Quick rub down with sand paper and it turned over perfectly. Covered it in electrical compound so no more rust.;)
Thanks for all the help and suggestions guys. :cheers:
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
i think about 3 people told him that about twenty odd times.
good to hear its working again though. I know what a bother it can be if your precious don't start hahaa
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Yeah most of you suggested the starter motor, top boys! I checked everything people suggested and found the fault.
I now know what a dodgey starter motor sounds like now;)
