Car running rough, coughing then back firing
bullseye
Hi was wondering if anyone can help.. Car running rough, coughing then back firing, tried replaced sparks, temperature and air sensors still spluttering into life after revving engine... Anyone got a clue????:shrug:
Jul 8, 2007
514
If you get it on vag com will tell you which cyclinder in missfiring altho you should replace all 4 at ones as the others will follow, i got mine from euro parts for about £30 each
shauncupra
59
Norwich,Norfolk
i had a simalar symtom with mine a couple of years ago, mine turned out to be a a cracked/broken away vacuum nipple underneath the inlet manifold (not seen) causing the fuel pressure not to rise in the fuel rail under accelaration.
(this vac pipe goes from underneath the inlet manifold to the fuel pressure regulator)
see if thats all ok aswell matey.
SWANSWAY CUPRA Dealership
