Car stalls when started
markmeus
Mark Graham
Jun 9, 2007
2,948
11
Banbridge, Northern Ireland
After 2 1/2 years of faultless ownership, I now have a little problem with the car.
When the engines cold and I start it, the revs drop and it will stall. Now the idle has always been a little jumpy when I start the car but it's never been enough for it to stall untill recently.
Now I've searched and came across threads about cars that stall when idling, even when the engine's hot, mine seems to only do this when the engine is cold.
A lot of threads mention throttle body alignment, is this likely to be what's wrong or does that information only apply to Cupras?
Cupra Gsy
200
I know this will sound stupid but there is a little round plastic cover that goes over your ignition which reads the code from your key etc
Well mine was doing this and the garage told me to change it which cost around £10 and it worked.
Gordz
Caught The Mod Bug Again!
May 31, 2007
1,325
North East
Mine used to do this, turned out it just needed new spark plugs. Could have a look at replacing them? Not the most costly of things to go wrong if it is that!
sortu
Got To Love Diamond Audio
Jan 5, 2009
181
Milton Keynes
