I've got Carista, managed to disable seat belt warnings and door open when key in ignition. I haven't tried any other options as i don't have parking sensors or a camera
I activated needle sweep on a previous leon but have digital dash on the Ibiza so don't want to mess anything up with that
I have Carista and its very limited.
for example: you can't code the windows to close in single press. I tried and you don't have the option for this.
I sent them email and they told me that you can't change it to prevent injury from the windows or something..
in OBDeleven you can do whatever you want by changing the codes.. the example above you can do in 3 minutes.
Isn't OBDeleven aimed more towards pro users and involve changes to parimeters in the software where Carista is just a click on the option and easily reversible?
With OBEleven you can do long coding (Changing parameters manually) or One Click coding (Where you still change the parameters but these are pre assigned and tested so you can’t make a mistake).
