I am having a problem with the central locking on my 03 plate Alhambra
The drivers door will not completely lock or unlock when pressing the fob, all 3 other doors and the boot hatch lock and unlock correctly. The fuel cap is also mirroring the problem with the drivers door
The drivers door will lock and unlock but it does not do it completely. For example to start with all doors are unlocked. If I lock with the fob the drivers door will half lock, passenger and rears doors lock fine. If I then unlock the drivers door locks correctly but the passenger door and rear doors are now unlocked. Lock again drivers door half unlocks, passenger door and rear doors lock, unlock again, drivers door unlocked, passenger door and rear doors unlocked
I have had a new drivers door loom put in as the wires had been played with by a previous owner but this did not cure the problem. I then had a new drivers door actuator fitted, this also did not fix the problem
Has anybody had a similar problem ? If so what was the fix or any other areas to try. Have checked for fault codes and there arent any present
I am running out of things to check and change
