Changing Brakes What Tools Needed?
Oct 31, 2006
870
Cambs
As title really, changing my discs, pads ( on front) and fluid just wondered if you guys have any handy tips on doing this? and if there is any special tools?
WeeJase
pert
Jun 2, 2001
8,595
you are going to struggle bleeding them on your own,you need a friend or an e-z bleed.the rest is just normal tools/spanners screwdriver/drill for the pesky disc rettaining screw
caliper wind back tool is a great help too
Oct 31, 2006
870
Cambs
so by the sound of things it's the retaing screws that are a bit "tricky" to get out. As for the bleeding i've got a mate coming over to help who calls himself a mechanic on weekdays,
Can i use a big set of pipe grips instead of a wind back tool?
mk1golf_jack
Golf nut
Mar 13, 2007
80
Herts
You could do but you might catch the piston seals, just be careful, its a 17mm socket size to get the caliper bolts off. the disc screw is an arse! good luck
Oct 31, 2006
870
Cambs
I'm using ferodo ds2500 pads and in the box there is 4 bolts about 25mm long does anyone know where these might be for? my first guess is they are replacment bolts but for what i don't know? caliper?
Oct 31, 2006
870
Cambs
Good thinking! i think i've got a couple of g-clamps kicking about somewhere, i had a look today for a windback tool but in my local motor factors i could find one, so i will probably use a clamp instead.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
You wont get the rear caliper pistons back in with a g clamp or a set of mole grips lol. You need to buy a Laser Brake Caliper Piston Tool for that. Other than that you'l need 13,14 + 15mm spanners and a pozidrive screwdriver but id you an impact driver as the discs are on tight
WeeJase
pert
Jun 2, 2001
8,595
good job he is doing the fronts then ;)
oh yeh,when winding back caliper,take res cap off .eases the pressure
SWANSWAY CUPRA Dealership
