Changing spark plugs...
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Is it possible to change the plug nearest the passenger side without moving the turbo->smic charge pipe? I can't see how the coilpack could be removed otherwise.
r1cky
Banana Rama cupra car
Oct 12, 2004
222
would also like to know this as im changing mine next week, what type of plugs do people use? always used Bosh 4's in other cars ive owned.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
no - but you can undo the mount at the front & push it over just enough
flashbsd
ditto, just changed mine thanks to hooch's advice :)
i had to remove the samco hose to free it up a bit more also, but you can easily get coil out etc
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Old thread bump, will be chaning my spark plugs this week, but wondering what size spark plug socket i need to use? Going to have to buy one from halfrauds as i cant find any in the garage!
Anyone know?
warren_cox
Back from the dead
isn't it a 14mm deep socket (and then you choose 1/2 or 3/8 drive depending on what size ratchet head you have)?
You can get a tool from Hellfrauds by a company called Laser for doing this. Their best tool is a flexi shaft driver for doing up 6/7mm jubilee clips (cheers to m0rk for enlightening me to this)
warren_cox
Back from the dead
Phil you are right, they are 16mm around the plug body (see image below)
However, if you use a Halfords plug socket they call it a 10mm (confusing??? - see below)
Need to get a torque wrench out to check mine after seeing your thread the other day.
Feb 25, 2007
657
stroud
yes you can its a fiddle but i have managed it i run NGK PFR6Q in mine they last and work a treat jabba sport put me on to them years ago
