Pull on the plastic surround with a trim removal tool, pull it inside out and then cut the clip off. Knob should pull off...
First you need to remove the silver trim, i used a credit card to slide it up and out. Once thats off you need to release some clips, if you press down on the gaiter you should feel them, press them outwards and the gaiter should pull up.
