I didn't put any on the horizontal of the window, doesn't need it really!
the second pic sort of shows the inside of the window, but best to just have a look yourself and you'll see
very good idea im def gonna try this.. both my windows hav just started makin the air sound ha.. soooooooo anoyin an as u said we dont hav to go deaf anymore wit the loud music.. very good hav to give a go! :)
Going to do this after work.
So, a strip on the top of the door once you have opened up the channel? And the back of the door to?
Luke
yeah, along the top and then down, both on top of the door and inside the window area?
I have just done this on my mk4 FR and I used some windscreen washer tubing that I bought from halfords a while ago!
I used the 4.7mm internal diameter pipe and it fits nice and snug in the gap, I must admit that the difference in wind noise is much better than what I expected!
This is a must do mod for anyone! Plus you can buy the pipe for £1.50 for 2.4M at the moment (bought some more today as I only had enough left to do one side), the 2.4M is more than enough to do both sides!
Just digging this thread up as am going to give this a go myself. Shame the pictures have vanished as I'm not quite sure where to put this rubber. Anyone got any pics?
Creator and inventor here :) don't expect any miracles, but it defo helps, I dont use rubber anymore and instead bought some 5 to 7mm draft excluder foam which fits perfectly in the channel !
can get from most diy shops, most B&Q's sell it or flee bay
Thanks for the reply! I've had a go today and taken some pics which I will post later, I've not driven the car yet but think I have done it right.
So we are talking about behind this fabric bit, the void in there.
I cut some rubber like this.
And pushed it in like this.
And this.
That's all I have done for now but I know the other part you mean that is only visible when the door is open.
Is it an idea to fix this with a COAX (as we call it in Holland)?;
Or will it be to 'thick'?
