On the Passat PDs the turbo and VNT mechanism is at the front and side of the engine, exposed to road spray, salt etc that gets through the radiator. I wondered if this would cause the actuator linkage to get a bit sticky over time.
Over the weekend I got a small can of WD40 and soaked the area where the VNT actuator rod goes down to the turbo housing (engine cold) and left it overnight -- NOT spraying the actuator body (the mushroom shaped thing with the vac hose). Gave it another spray in the morning, then took it for a drive.
Got better throttle response, especially at low / medium revs. Could be worth doing once every couple of months or so .....
