JonTelfer
On the crab
Jan 24, 2007
187
Hi All,
I've got an Altea FR TDi and vag-com - aside from the usual checks for fault codes, what else is worth looking at before the warranty runs out?
Thanks in advance,
Jon
Autoscan log
OK - Thanks - here it is:
Code:
Wednesday,23,April,2008,20:59:51:10373
VCDS Version: Beta 803.1
Data version: 20080309
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: Something5PZ6something else   Mileage: 44420km/27601miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 03G 906 018 EC    HW: 03G 906 018 EC
   Component: R4 2.0l PPD1.2 G    9583
   Revision: --H02---    Serial number: SEZ7Z0E3192442
   Coding: 0050072
   Shop #: WSC 02108 476 04707
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0006898
   Shop #: WSC 06402 785 00200
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 5P0 907 044 B
   Component: ClimatronicPQ35 008 0303
   Shop #: WSC 00000 000 00000
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003976392
   Coding: 81880F2700041000001E00000100000000007F0B5C
   Part No: 5P0 955 119 B
   Component: Wischer SE359  012  0402
   Coding: 00056272
   Shop #: WSC 06402
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: S9 AIRBAG VW8   018 2300
   Revision: 04018000    Serial number: 0038MD0DL161
   Coding: 0021305
Address 16: Steering wheel        Labels: 1K0-953-549.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0002042
   Part No: XXXXXXXXXXX
   Component: E0221           005 0060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 5P0 920 941 A
   Component: KOMBIINSTRUMENT VO3 0518
   Coding: 0002401
   Shop #: WSC 01128 210 66661
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001063288064
   Coding: 3D3F03C0078203
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VO3 0518
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2490
   Coding: 0000656
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
Address 46: Central Conv.        Labels: 1K0-959-433-46.lbl
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C000DC2D0005054C5F863000CC
   Part No: 5P0 951 171 C
   Component: Innenraumueberw.009 4865
   Coding: 00000000
   Shop #: WSC 00000
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Coding: 0000656
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 5P2 035 186
   Component: Radio BVX           0017
   Coding: 0040400
Address 62: Door,Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2426
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 B    HW: 5P0 862 335 B
   Component: FSE_2P5x        H21 0060
   Revision: 00000001    Serial number: 00000000415035
   Coding: 0000555
End   ---------------------------------------------------------------------
So there's something up with the driver's window - I had noticed it get to the top and drop down again but it's not done it for a while... What should I look at now do you reckon?
Thanks,
Jon
