JamesRL
Hi guys
I'm a bit new to this, but i need to ask you guys, if you have had any bad experiences with chipping a Ibiza TDI?
Is the quality of the car made any better?
I don't remember there being an SE version of the mk2 Ibiza.
SXE? or mk4 SE?
Anyhow if it is the SXE then I've messed around with a couple of those units.
Tuning box gives you big wallop of torque at bottom end and a better top end.
Re-map gives you a smoother wallop of torque and a better top end.
Uprated injectors give you a factory like power delivery with just a bit more of everything right up through the rev range.
I've also mixed and matched the above and would have to say that the Upsolute re-map is the best stand alone mod, add in the injectors and it's very very quick (for a non PD Diesel) but fuel economy goes out of the window somewhat.
Thanks GTV, just another question im guessing you have the 1z engine too, do you have an 8 pin or 10 pin as i haven't picked the car up yet and might just order one now so i can have the power sooner.
No I have a AHU engine in mine I am afraid.
Cheers stew i think i'll play it safe and wait till iv'e got the car here then just to make sure it is the 1z and does have an 8 pin not 10 pin.
