Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Allard Intercooler Pipes *Fixed*
Spoke to Allan about my problem getting the OEM turbo hose onto the Allard pancake pipe and it turns out the Allards pipe was made slightly wrong. Allan promised to send me another pipe out made to the correct spec. Fitted it all tonight and fits a dream now.
No boost leaks now, everyting is sweet once again!
Thats much better Chris. I see your using stock Turbo Outlet..SFS pipe is good however has to be angled in such a way that it wont rub - which by the size of it is very difficult. I doubt you will notice a difference in performance anyway.
Hi Chris, why did you decide to go back and use the OEM turbo outlet house??? I'm guessing due to teh rubbing issue you had??? Have you noticed any difference in the performance between the two hoses??? I was gonna get the SFS kit as my OEM outlet pipe is a very bad fit intot eh turbo housing, I presume it is worn out?!?!? I've just ordered my allards kit and don't want to havce any hassles in fitting it!!! Also don't want to order the SFS hose if it's gonna cause problems for not noticeable increase in performance. I'll just get a new OEM one!!!!
bloody hell that was quick mate. You done a superb ad and its obvious your car is in tip top condition.Sold.
06/03/2010.
is the new owner going to join scn - and how is the LCR search going?
did you get what you wanted for it?
