Hope you all had a very Merry Christmas,
Bought myself what seemed a decent Induction kit, Revo intake. Been looking into intakes for a while, seeing what people's opinions were on different kits. There were the usual top 3 or 4 which usually boils down to which one you like the look of most, other than that they probably perform the same.
Made myself a kit to start with thinking it would save a bit of money; spent about £180 on it. Performance wise it didn't seem to do much other than make the "Darth Vader sneezing in your glove box" Noise.
[/URL][/IMG]
After couple months thought I'd give a decent, car model specific Intake a go...
[/URL][/IMG]
Wasn't too bad to fit, the MAF to Turbo pipe was a little tricky and the front facing heat cover bracket didn't fit properly but it's still pretty sturdy and the MAF sensor plugged straight in.
[/URL][/IMG]
Good looking kit I'd say. Verdict is.. impressed! Over the kit I had made, this Revo one is definitely noticeable from approx 2500/3000 rpm to about 6000 rpm. Don't think you need a DV either, it's a noisy kit, but that's what you get from an open cone filter. And with the
help of a singe piece alloy pipe which slightly narrows at the MAF sensor and smooth silicone Turbo pipe connector it obviously helps with better air flow. Only down side to this kit is it's expensive.
