Cigerate Lighter Problems
mattytmc
Hey all,
having a slight problem with my lcr 225. the cigerate ligthers do not work. this is the one in the front and also the one in the boot. is there a fuse for the lighter in the car if there is i can check it. but jst wondered if anyone has had any other problems like this.
cheers
swilky23
230
rochdale
you will have to have a look in the handbook for fuse number i presume there is one. When you find out the fuse number they are located on the side of the dash if you open the drivers door and look at the end of the dash there is a panel that pops off using a flat screwdriver hope this helps
mattytmc
ok cheers will look in morning, is there nything else it could be if it not the fuse?
