Climate Control - Constant rushing sound
Nov 29, 2007
736
Mansfield, Notts
As the title states... My climate control has a constant rushing sound, almost like water forcing its way past an almost closed valve. It is loud enough to here even when the radio is on low (volumn 10-12). I'm thinking about getting it re-filled but that would be a waste it the issue is terminal and a new unit is required.
I've been searching through old threads/posts but so far haven't found anything describing the same sound. Any info or pointing out a relevant thread would be appreciated...
munkyboy
106
Cardiff
I had this noise coming through into the passengers footwell. Its fixed now but my problem was when i got my car serviced they didn't fit the scuttle panel properly so all the water was going through the pollen filter and into the car which made a sound like there was coming through.
Nov 29, 2007
736
Mansfield, Notts
I've got no issues with water coming in, misting up and I'm fairly sure the pollen filter is only 1 year old. I've had a look and can see anything.
I was wondering if the gas was low would it make this noise?
