Climate Control Problems
Vag_Dave
!! Diesel Power !!
Jan 15, 2007
76
South Wales
Hi Guys.
I've got 2 problems with my Climate Control, the one problem i have had for about a month and the other one i found out about last night.
1. When i put the climate on HI it blows out realy cold air and it doesn't change for the hold journey. and the last couple of week the weather hasn't been the best.
2. When the climate is on at any temperature and i put it into reverse the fans start going quicker, then as soon as i take it out of reverse it goes back to normal.:doh:
Has anyone had this problem before, if so how did you solve it? or if it's not a problem that anyone has had do you think it would be a warranty issue?
Thanks in advance
skott101
43
Manchester
I've never heard of that one before. I'd guess that it's a bad earth somewhere.. I'd start by earthing a piece of cable to the chassis and put it to the earth connection on the back of the climate control panel and see what happens.
Definately sounds like a warranty issue if your car is new enough!
Oct 17, 2006
2,141
Mid Wales
1. Sounds like a temp sensor fault
2. This is normal - the system goes into recirculate mode when reverse gear is engaged to stop you sucking your own exhaust fumes into the car - clever system ;)
Octane2097
Naturally Aspirated
Jan 20, 2007
792
South Yorkshire
wait so the cars climate control swiches to reverse mode when you engage reverse Sweet....
but if ur front wipers are on it and you select reverse dosnt activate the rear wiper?
which is annoying since my girlfriends s reg fiesta does!
Vag_Dave
!! Diesel Power !!
Jan 15, 2007
76
South Wales
To be honest i don't think this is it because i have had the car since the beginning of February and it has never done this before.
I still have warranty on the car until December 2008 so i'm hoping that it will be covered.
Any other ideas? :)
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
er well every beeza with CC i have been in does it, which is a fair few including all trims (referance, 1.4 sport, fr, cupra etc both before and after facelift too. and it isn't reverse mode mate lol. otherwise it'll be sucking air out of the car :blink: you have a button on the CC controls which activates the recirc instead of suckin fresh air in it blows the exixting air around, easy. simple way to test is to sit there with the CC on nomal then press the button, you should here an identical (louder) blower noise to when your in reverse
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
what davels said is deffo correct, they all do it
you don't want nasty diesel soot up your nose in the morning as you come off of your drive do you
Vag_Dave
!! Diesel Power !!
Jan 15, 2007
76
South Wales
I understand what is being said, but my query about this is Why haven't i heard it before.
In the 4 months that i have owned that car i have reversed it with the CC on more than just that time last week.
Nath.
Jan 1, 2006
8,619
16
there are quite a few things that your car does that you will not have noticed yet
try putting your indicator on with ignition and lights off...............
try unlocking your car and not opening a door for 2 mins................
I could go on but it would spoil the fun
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
there are loads of things that you may or may not notice mate, could be howe hard your concentrating on drivin, how loud you stereo is at the time, passengers etc.
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
I want to know more little tricks that my car hasnt told me about. Ill try the reversing thing lata but ive never noticed anything about the indicators??
well the locking thing is if ya unlock the car and don't open one of the doors is autolock as a security feature.
the indicator thing is if you leave the indicators on it leaves the rear light and front side light on as a sort of parking light, so left side on for the indicator in the left postion and viesa versa, tis cool[B)]
Mellie39
Yellow Ibiza
Mar 21, 2007
7
Croydon
Also if you shut your car with your windows down and use the key rather than the central locking to lock the doors, the windows will go up.
Well it does on mine should do it on everyone elses!!
I hope!
