clock resets everytime i start the car
Tucker157
1,066
Falkirk/Central Scotland
+1 for battery being first call!
The electrical items require a good 11.4 volts at all times to function correctly. In the factory repair manuals, a lot of fault correction starts with check the battery for 11.4v
Sent from my HTC Wildfire S using Tapatalk 2
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Check your battery terminals, i once forgoten tighten them and every thign reset in a few mins when ignition is off
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
Did I say that fuse behind a head unit? In fact we're not even talking about a head unit..........
There's a fuse that controls permanent power to components, then when you turn ignition on that power is through another fuse and will enable things to power on....therefore if perm power is lost things will lose memory but turn on when you power the car on!
Tucker157
1,066
no? your car wouldn't start. If it hasn't got enough power to power a little clock it wouldn't start your car!
If you'd read the OP you should notice it says when he starts his car, (not just the ignition stage, which as you previously said if it was the fuse you speak of, simply switching the ignition on/off would clear the time.) so if the batt has enough to start the car but no reserve then the clock etc will lose info because all avail power is being used.
To the OP:
All fuses should be checked then a new battery fitted and take it from there. Eliminating power source problems and allowing you to continue to the next diagnostic stage.
I have seen a BMW which done odd things with an apparently perfect battery. Used to do funny things including putting all the windows down when starting or coming up with phantom faults. A new battery solved it all. Cars these days rely on computer power very heavily. And we all know computers aren't reliable!
