Solly1010
48
Hi guys.
Got a clunck noise coming from nearside front. So whats been changed.
Poly adjustable ARB links
Poly shocker top mounts
Nearside track rod end.
Off side ball joint
The wishbone bushes are polys
Dog bone bush is poly
First it was clunck both sides now clunck is on the nearside only.
Only thing left is nearside balljoint
But this looks okay?
Any help appreciated
Makes a clunck on uneven road and also when slight turn left or right also cv joint nearside been changed as the boot was torn
Go around and make sure everything is tight, I had clunks after my roll bar link was changed but turns out it hadn't been tightened properly
