Clutch issue? suspicious noise from uphill start
Cupra R MK2
75
Manchester, United Kingdom
H
I've just had mine fitted last month. It makes a rotating metal on metal like noise when coasting.
Had it for nearly 4 years, and no issues, the steering is much sharper and quicker, I get no grinding noise when coasting, it really goes in well in tight corners, gonna see if I can get a recording of the clutch noise tomorrow, one thing I forgot to tell, this clutch noise started when I installed a re-enforced clutch plate from Sachs, before that there was absolutely no clutch issue at all
Cupra R MK2
75
Ok, got the car back, that vibrating noise when I go uphill is attributed to the very firm REVO engine mounts which shakes everything
I also managed to get a Forge spacer hooked onto DV+ Diverter valve, to do this you need longer screws as the DV+ Diverter Valve comes re-enforced, and the original screws with the Forge Spacer are too short
