clutch pedal problems
dai cupra
hi after my clutch pedal broke i had it welded and now back together . it feels to slack the pedal goes half way down before the clutch engages anyone had these problems before many thanks
davidsonley1
193
Middlesbrough
Same thing happens to mine mate! What springs u on about? I have like an inch of play at the top of the pedal before it becomes really heavy nearer the floor :s
David!
dai cupra
same here mate behind the pedal there shuld b a spring i gota make sure mine is in secure as it clicks on way out lol
dai cupra
behind the pedal its self there should be a spring check to see if it has moved . have u had the problem with clutch pedal snapping yet
davidsonley1
193
Middlesbrough
ahh i see! yeah mine snapped about 6 months ago so i welded it up. Got a few new pieces from my local SEAT dealership and fitted them (white clip and a large white clicker type thing <--great description haha!) anyway..over time theres now play in the top of the pedal like i said :s
I'l have to get under and have a good luck..could be an easy explanation..
David!
Sandy1985
85
I mentioned the spring because when I had my clutch pedal welded up I couldn't get the spring back in so just left it off, over time I noticed I couldn't get into gears, anyhoo if you put got foot under the clutch and pull up and it comes out a bit, you will know what I mean when you try it, then the spring is missing/ not in place correctly... Give it a bash let me know if any effect
Jan 8, 2008
528
Portsmouth
if its the problem you will need to remove the lower scuttle panel, at the top of the pedal (well under the dash!) will be a black box with a wire on it and a small white plunger that touches it! it is screwed into a bracket, when the pedal snaps it usualy rips the thread off and knocks it out of adjustment! (made of plastic) just screw it in or out to adjust!
dai cupra
is it a white sensor thing wich pushes in and out is it a white thing
