When i rest my foot on the clutch i can feel a vibration and when i press it down to change gear.The garage say this is normal with a tdi.
Its not a massive vibration but i do find it annoying,can't remember if my other cupra tdi did this![]()
Mine does this, always has. Not got any worse overtime so I'm not too worried about it.
If I remember correctly, raising the revs slightly maves the vibration pulse quicker, then raising the revs even more makes the vibration go away.
Yup that's what i did on mine in VAGCOM - raised it to 945rpm and it made it a lot better. Fairly sure it's the Dual Mass Flywheel that causes it although i've no idea how 'worn' it has to be for it to happen.
Can the RPM be dropped after been increased via VAGCOM mate?
Out of interest, does the vibration go away if you raise the revs slightly?
Not really,i have had my cambelt etc changed a few weeks ago and don't remember this vibration before,but the garage say as the clutch cable is conected to the engine it will always feel like this
just to add, same car & stock and I have no vibration at any point when pressing clutch pedal.
never had that i recall over the last 60k anyway.
no wondering if should
my rpm has always been high and vag-com says 903 -> is that normal high or set high?
what are the reasons for adjusting idle higher then ???
to add i dont have any vibration that i noticed
on the other hand markwales has something , suspect its the thrust bearing i think he said but this makes a noise pressing & depressing clutch
