iain123
Hi Forum
Thanks for taking the time to read my posting.
I have a 2009 mk5 Ibiza 1.4 ectomotive, which has done 106,000 miles and have owned the Ibiza from 2013 when it had done 96000 miles.
Currently I get the code P0243 when l look it up is "Turbo/Sup Wastegate Solenoid A Malfunction". On clearing the P0243 code it immediately reappears.
I have not really noticed any difference in the driving experience of the Ibiza and still get a good millage to the gallon.
Prior to this I had been getting the code P0299 Turbo/Super charger underboost, say every two months for about 9 months, but I could clear this code and it would stay "away for a while". I noticed a small oil leak to a large diameter rubber hose entering the turbo and replaced the o-ring as it was damaged.
I believe the Turbo/Sup Wastegate Solenoid A is also called a Turbo actuator?
And may go by the name N75?
Any helpful input appreciated, e.g. due you think the turbo actuator is likely to be faulty, where do I find it and is it easy to repair fit a new one.
iain
Hi Forum
iain
Have a quick read here - http://www.datsc.com/tabid/122/OBD-Error-Code/P0243/Diagnostics/Volkswagen/Default.aspx
Thanks DEANO
Taken from the website I was advised to check out by DEANO
Causes
Possible causes of OBD code P0243
- VPWR circuit open to SCB solenoid. - SCB solenoid circuit shorted to PWR GND or CHASSIS GND. - Damaged SCB solenoid. - SCB solenoid circuit open. - SCB solenoid circuit shorted to VPWR. - Damaged
SCB = Supercharger (Boost) Bypass solenoid circuit
VPWR = Vehicle PoWeR Supply Voltage
So I now need to find the Turbo Bypass solenoid and circuit?
I will try and get a workshop manual off the web
iain
