Just wondering where would be the best place to feed the cold air pipe to the front and weres the best place to have the end. Would going between the battery and the wing be best?
Im thinking of getting a fmic. But would it be worth it without a remap? Although I do plan on gettin it mapped at some point in the near future
Thanks for all this info. I think I'll go ahead with getting stage 2 mods and eventuallu get it mapped. Just not sure what I want to do first engine or styling lol. Ill start a thread with pics with my progress when I get started
it comes down to this, improveing performance on a engine relie's on a couple fundamentals...
How fast/efficiant you can get fuel into the engine and how fast you can get exhaust out. Its almost like the metabolism.
This includes Air aswell as petrol
So a Turbo increases the amount of air put into the manifold it compresses it, but when you compress air, it heats up, a FMIC cools it down again, cold air is denser than hot air, ie, contains more oxygen. thus is more efficiant.
A larger Exhaust, 3'' downpipes and stuff people have, increases the rate at which you can get rid of the waste gasses, thus a larger exhaust pipe is less restriction, same with cat's and silencers, they all reduce something, ''emissions/noise'' but you gain more restriction. So people cut them out. Im getting the silencer removed from mine soon, it gets you like 7BHP! thats like, almost a SCN stickers worth!
Bigger turbo's, bigger exhausts, better performance Maps, intakes, FMIC's all will increase your performance, but as i understand it, its ''safer'' to prepare the car with a FMIC/exhaust etc, before adding more boost, via a map. i dont know the exact details of a map, but i assume it increases the spool rates of a turbo, aswell as the engine management of how much fuel is used, etc etc.
If you put a maaaaaaaaaaad map on without the pre work, your forcing your motor to run faster, hotter, stronger, without giving it room to breath. You wont see a massive gain from a map without those mods first, imo, its better to get the stuff sorted first, then have a map for your setup.
I believe its called a ''Stage 2'' when you have those supporting mods. Stage 1, is just a map, which will give you more BHP but its stresses stuff more.
2cents/
I dont know much about it all, so feel free to correct me. id love to learn more.
Josh.
