Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Hi Kev,
Any more probs since as I have the smae prob. Can't see any split pipes and runs fine after 20 seconds or so. If i turn engine off and back on again it works spot on. replaced air filter 2 weeks ago.
I have changed the temp sensor and air filter and still no difference....I have really slight flat spots in low revs. Would that be MAF? It was replaced a few months ago.
Finally sorted cold start and hesitation problems, Heres what i did.
Replaced split hose under manifold (sorted engine light) £15
replaced Temp sender unit (made no difference)£7
reset Throttle body (made no difference)
stopped using fuel from supermarkets a couple of days ago ( improved performance but didn't cure problems completely)
today i cleaned throttle body,replaced air filter,replaced plugs.£25 waited six hours to make sure it was cold started and drove of straight away drives like a dream and didn't miss a beat, didn't realize how much power the engine had. now getting average 31 mpg. well please.![]()
im so glad you posted this!! ive been having all these problems.. going give it a bash this weekend... my mpg is shocking right now..![]()
kev....one more thing. u mentioned you cleaned the TB then reset it a week later. can you drive the car in that time? what difference does it make if it is not reset?
cleaned the TB this afternoon...can tell a difference straight away. Need to try when cold. Will keep you posted.
