ive had mine for a week now and its brill !!!!! well worth the money top marks from me..
I just ordered a pingi after reading this thread.
I did wonder if it was the wind deflectors I have on making it worse ?
My Pingi arrived today too so will report back![]()
I ran vag last night and got this error
Dont know whether this is why my cabin is misting up ?
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
00792 - A/C Pressure Switch (F129)
000 - - - Intermittent
condensation on the inside is usually caused by a leak in the air-con system or a blown heater matrix
if your air-con or heater aint working then that's your cause (most likely)
pollen filter is less likely, and you can tell when your pollen filter isn't working properly when outdoor odours get into the car very easily (obviously with everything closed)
another less likely cause is damaged seals or water in the cabin...
as i said, check your heater and air-con is working properly before looking for anything elsethis has happened to 2 of my mates recently and is the most common cause
