hi guys changed my thermostat today due to when I was driving it went right up and the pipe that comes from the thermostat was cold, so I have changed this and bled the system and went for a drive and the temp started to rise again and the pipe was cold again after s new thermostat but as soon as I pull over it goes down
When I open the cap on the expansion bottle it becomes hot and when you turn the engine off it sounds like loads of air stil in there
I'm hoping I'm not going to need todo the water pump is it just a case of bleeding it in a special way ??
Thanks in advance guys
