Momochi
164
62
UK
Just wonder if there is a coolant temperature gauge shown in the dashboard (virtual cockpit)? Or need to have the system coded in order to have it shown all the time?
I consider this gauge being one of the most important item for an ICE vehicle, if not THE most important. Just a warning light in the instrument cluster for overheating is definitely not good enough.
Thanks.
Use the upper 'Right/Left' button on the right hand side steering wheel control to navigate to the left hand centre 'window' Then use the scroll wheel to scroll through the options until you see the water temp/oil temp displayed then press the scroll for OK, or leave it to exit. I keep it displayed.
I would also point out if the MK4 is anything like the MK3 the oil temp gives a sensible temp but the Water Temp when up to temp shows 90 but if you use an OBD11 Dongle you will see the real temp (Which can be higher than that but not dangerously high).
