Hi all,
Im on a quest to find my hesitation at max load. I found some oil around the standard Turbo inlet pipe.The oil is where it joins to the metal pipe and also where the metal pipe joins to the turbo.
Could this leak be causing my car to surge then hesitate at high gears when car is under most load?
p.s car is an octavia vrs, and the hesitation only started after remap.
