Chrisjop
25
Recently bounced my Ibiza off a few kerbs as my rear tyre burst at 50, bent one of my Alfa wheels, track arm and track rod end replaced as they were bent but I still can't get my car any where near right on the tracking machine (N/S wheel is straight O/S is still facing in left a bit, and it has a lot of camber, I'm wondering if anyone else has done something similar and what did you have to change? I think I could have buggered the steering rack because I can't think of anything else that keeps the wheels tracking straight, any help will be much appreciated.
I don't think that tracking you want to get done, but 4 wheel re-alignment as the subframe might have moved a bit. Also a place with proper alignment table will be able to tell you what is any thing still needs replacing.
Took it to a garage with laser allignment and he said to put it back on the standard struts and then try again as you cant get a true reading or something
Sent from my SM-G361F using Tapatalk
When fitting the struts yesterday realised that one of the sliders on the caliper is bent, could this have been caused by the accident?
