Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
So I take it everyone is getting the same creaks as I am like in the video I posted?
What do you mean by door seals?
The rubber?
Yep the rubber that you see around the edge of the door frame.
At first I used Autoglym vinyl and rubber care as I had some in the garage, but then I was in a local motor factors and found this http://www.amazon.co.uk/Holts-RL2R-150ml-Rubber-Lubricant/dp/B00518H8Z6
Was cheaper from the motor factors too!
It's much better and has stopped the creaky noises.
Do you know if this works?
http://store.carcareeurope.com/einszett-proteccion-de-gomas.html
My cupra has creeky handles, and it creeks under the speedo inbetween the steering wheel lol
Anyway creaks are only covered up to 6000kms right?
Mines were all covered up until the point the warranty ended
