p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
please could some1 help me......my drivers seat is creeking like mad from the botom not the back n its driving me up the wall im gunna go mad soon if i dont sort it.......what could it be.......
please :help: me
:cry:
Is it from the seat base or the seat fittings on the floor?
If its the floor, you can replace the rubber guides for cheap (they're common to go) but if its the base, it might need a new wire or even worse, a reweld.
Pull the seat about with your hand and see where its creaking from.
My drivers seat frame was creaking and sqeeking for ages, and the other day the frame just snapped.
Any idea how to remove the whole seat in order to do a re-weld?
The seat itself is held in by an allen bolt and a hex bolt. Pull your seat towards the steering wheel and you'll see it in the centre of the seat base. Simply undo this, remove the trim from each side of the rails and then use the handle to slide the seat all the way back. Pull the seat up, remove an airbag cable if it has one and remove it from the car :)
mine does the same! drives me mad! everyone thats in my car always takes piss sayin that its cause i do to muchshaggin on it! but funny thing is i havent and wudnt! wudnt wanna get marks on the nice red seats!!
my also does this, think its from the back of the seat rather than the base though ???
mine also done this. its all to with the pimp handle, if the seat is sitting high mine wont creak, but adjusted all the way down, it sounds like a bed in a brothal.
My old Polo did this when I first brought it. Took it back to the dealers and they found the seat base had broken, causing it to creak.
take the sear right out
just grease the rails up n the will sort it right out did mine bout 7 months ago n still not a peep out of them;)
dont need to unpug anything m8, just undo the allan key siz5 i think mabie 8,
then slide both plastic bit out of each side of the back of the rails.................easy
