Wizzard
Hello all.
I have an 06 tfsi sport with no cruise control when in sixth gear, all the other gears have no issues at all at any speed but when in sixth it will not engage at all.
It has been connected to vcds but that showed no faults, the car has been re-mapped before my ownership but by who I don't know, could this possibly be the cause?
Thanks.
As it's working ok in the other gears, I would hazard a guess it's related to the gearbox/lever in some way, it would appear that the cc doesn't recognise when you are in 6th. Have you got a gear shift display, and does that work?
No gear shift display I'm afraid as it's only a small mfd, but did check on vcds and its showing it as a six speed box.
Does your gearbox have a neutral position sensor? If it does I'd check the output of it with VCDS when in 6th.
