Have ecu from aqx motor and fitted into ayp engine.....
would cruise control work if added it? dont want to go through hassle/money for noe reason...
Google the procedure for turning on cruise control with vagcom, if you can turn it on your ecu will accept it. Mine accepts it and is an AYP.
I will be doing this in the next few months, I have done lots of research seems pretty simple. Fit stalk, wire 4 wires from it to the ecu plug and turn it on with vagcom. Check your clutch and brake switches work on the appropriate block (66 iirc?) and away you go... Cruise control retro fit.
Sent from my iPad Mini using Tapatalk HD
Cheers buddy
Same as that I've been mulling it over for a while now it doesn't seem too awkward
I'll let you know how I get on
can anyone confirm which numbers on the ecu the wires should go?
Found this document shared by badger but can't figure out how to count the pins from my ecu using this.
Well i left them a message if they want to sell me fitting instructions. Don't think they will do that but at least i tried ;)
