crunching 3rd gear
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Have problem but it could be minor or something serious. Think my cupra has an upgraded clutch but not sure as pedal feels hard. Normal day to day driving it goes into 3rd gear fine but when im reving hard through gears from 2nd to 3rd it crucnhes as if you havent put the clutch down,
Any suggestions?
lemonslap
In The Know
Mar 14, 2009
320
Kent
yeh give that ago. is there guide on here how to change gearbox oil? (cant seem to find one :doh: )
Nice and easy mate! you will need a 19mm hex key (maybe 17mm somone confirm?) undo the bottom drain plug, once drained do it up then removed the upper filling plug (mid way up the gearbox) fill till the oil flows out of the filling hole then re do up the plug btw torque setting are 30nm and it must be done on a completely level surface
Big_daddy
Oct 20, 2006
3,930
Brummy
so how many plugs sre there in total? 2 or 3? do you need any special funnel or just can pour it straight from the bottle. How many litres of oil do these take?
lemonslap
In The Know
Mar 14, 2009
320
Kent
2 plugs one drain and one to fill, you will need 2.8 litres 75w-90 fully synth oil, the bottles should come with a filling tube.
