Hi all, i have a 2015 Cupra 280 which is great apart from an annoyance with the clutch. When the car have been used for a few miles (say about 50) i get a vibration through the clutch pedal when changing gear, this is especially worse when changing at high revs. The vibration goes away once the car has cooled down. She has done £11k but the clutch issue has been there from day one.
I would normally suspect a thrust bearing issue but this seems unlikely on a new car, do these have dampers on the clutch fluid lines?
Any help would be appreciated, i know the dealer will jest say its fine!
JP
JP
