Deadly Ferret
44
9
Hi, i am looking to buy a fitted rear boot liner for my 2018 cupra st 4drive. Does anyone know if the boot in the cupra 4 drive is the same as the standard st? Also are there any differences between 2015 and 2018 models? The company I have found just offer 2014 leon estate liners and i am not sure if this will fit. Thanks
Yep it will.
Boot is the same - though the 'raised' floor or 'real' bottom floor does make a difference. Depends what you have.
Thanks for reply .. I have speced the spare wheel with seat sound so would this be the raised floor?
Umm, no - the seat sound subwoofer is in the spare wheel which is actually under the 'real' floor.
If you have the second raised floor this has a different dimension to the 'real' floor.
I use my raised floor and have a load liner and hatch bag - this means my boot floor is flush to the rear boot lip. If i take out the raised floor, there is a 2-3 inch drop from the boot lip to the 'real' floor.
Is the raised floor an extra? How will I know what mine comes with? Could I just order a liner for the lower floor and remove the raised bit if it comes with one?
Thats probably true - i know that when i ordered my hatch bag I had to chose which version i wanted it to fit - i chose the raised floor.
I have a 4drive with subwoofer (and spare wheel kit) and it does have the variable boot floor. When I ordered my trunk mat I read nothing about different dimensions and no one asked me about those either, so I think they are all the same size.
Reactions: S4BiT
I will be getting the hatchbag too.. I have had a few of them and have been pleased. I will go for the level floor version as looks like it will be a smarter job. Thanks for the replies... only got 2 more weeks to wait till it arrives...:dance:
My old 280 ST and current 300 ST 4Drive (bith with space save spoare wheel and SEAT Sound subwoofer) were/are identical, in terms of the boot dimensions, when the (standard) adjustable floor is in the upper position - the SEAT OEM rubber liner fitted/fits both perfectly (but not so well if the floor is dropped...)
Reactions: Jaco2k
The company are asking if I want the metal d rings available on the hatchbag. Or of it even has them fitted? Have any of you lot any wisdom on this?
Can only go by our FR ST, but that has 4 load lashing rings at boot floor height, 2 each front and back of the load area
Does anyone know what the weight the variable boot floor is rated at if its in its higher position?
Sent from my GM1913 using Tapatalk
