Cupra and Cupra R Skirts
valley
104
How would I go about fitting skirts if I dont have the lugs?? Bonding?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
No, best way is to buy all the proper clips as you can use the bottom ones as normal and can fix the top ones on with a strong double sided tape..........or the thing I would reccomend is genuine sticky back velcro as once its on its not coming off in a hurry.
Mines was pre facelift and this is how I did mine :)
valley
104
Nice one mate, dont suppose you have any part numbers for these clips, skirts, and jacking points etc as ill order them up this weekend.
Appreciate the help buddy
valley
104
Side Skirts
1MO 853 853 D GRU Left Side Skirt Primed £24.30
1M0 853 854 D GRU Right Side Skirt Primed £24.30
1M0 854 927 B GRU Insert Cover Primed £2.90
1M0 854 928 B GRU Insert Cover Primed £2.90
1M0 853 917 B GRU Insert Cover Primed £2.90
1M0 853 918 B GRU Insert Cover Primed £2.90
1M0 853 994 Clip x4 £6.00
1M0 853 910 B Locking Clip x14 £6.30
~ 1M0 853 139 Expanding Nut x2 £0.74
* 1M0 853 139B Retaining Clip x 6 £2.52
* N 904 553 01 Hex Nut Shouldered x6 £0.30
# N 015 439 1 Speed Nut x14 £5.60
# N 907 750 01 Torx Screw x 18 £3.78
Of these bits, which ones do I actually need mate? and are the side trims worth taking off and painting or buying new ones and painting them??
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
The primed side moldings are now £40 each for the fronts and £29 each for the rears as I bought mine not long back.
You obviously need all the top parts as there the 2 skirts and 4 jacking point covers...so these
I'm not sure what the other part numbers are without seeing the parts.
The bottom two are just screws and clips, if you want correct torrix headed screws get genuine ones, if you don't mind black pan heads [you can't see most of them anyway there under the car] get them from motor factors and save a few quid.
I hope this makes sense.....its really hard to tell what you need just by part numbers and quantities but basically if your going to the garage get the exploded diagram up and you want....
2 skirts
The genuine clips that fix top of skirts to top of sill [to be stuck on]
The genuine clips for bottom that screw into floor + skirt [be sensible, use short screws and seal to stop going rusty]
Some spire speed clips and screws to hold bottom clips to skirt + car.
Something double sided to stick top clips on
I expect it will come to about £200
