May 13, 2007
1,017
Denmark
Hi all
Can any of you reckon this? Does your Cupra R sounds like a diesel at IDLE?
I'm tired of my girlfriend that keeps telling me "It sounds like a diesel", so now I want to know if thats normal?
Best regards, Thomas
As above mine only sounds rough on initial startup. First 5 seconds max then settles down.
The secondary Air Pump is quite noisey. My LC is a bit like that, especially when its particularly cold.
My mate has an A3 that has the same noise.
I don't think is serious, and the noise is definitely common. Although, if yours is excessively noisey. I'd reccoment getting it checkedm incase its gone or going!
I think thats probably what you are hearing....
dont they have hydraulic valve adjusters it could be that they are the last in line while the oil pressure builds up from a cold start..... acouple of my old cars had these and from a cold start you could hear a light clanking noise for a couple of secs until oil pressure built up at the top of the engine... was alwasy okay after the engine had been started and run for a few minutes only seemed to happen when the car had been standing for some time like overnight ...just a thought now i have an excuse mine is a diesel (its smokey)
yeah, unless a tdi your car should not sound like that at idle certainly not at normal operating temperature. My Mk3 Golf GTI used to sound a little like that all the time at idle, turns out the timing belt was a little slack and slapping the casing, got it changed and all was well. Do get it looked at mate!
It's a trait of the VAG 1.8T engine...my old Mk4 Golf was particaularly prone to this.
The LC isn't so bad...especially with the new BF zorst ;)
