Tell
Popped up:
Or this one:
Does this appear on another thread ?. Last link has a Vin box to check.
Then you got the UK government recall link:
  • Wow
Reactions: jezyg and Syphon
I leave you to pass on the message to Terramar users to check. Our 2019 Arona was sold with a known rear centre seat belt fault with a tag on it saying don't use (that was from one of their two Seat stores). Similar situation. The local dealer did replace it when the parts came in. Seems a bit common. Probably repeat tests of the seat belts through up issues.
The Arona/Ibiza/Polo/T-cross rear seatbelt debacle was the result of the centre rear passenger having the ability to accidentally unbuckle the left rear passengers belt under extremely specific circumstances.
To fix the issue, VWG designed, successfully tested and fitted a spacer to the buckle to prevent any future instances.
There have been zero internal publications about the Terramar/Raval seatbelt concern.
  • Wow
Reactions: Tell
Perhaps they are keeping it quite. Not knowing what to say. Don't want to spread shade :unsure:.
I see Cupra has its own check site just in case:
EU has a specific site on it with dates for the Terramar
Born a pesky screw
More details on Raval and Terramar
Had my letter yesterday for the raval.
Not good if you have the faulty belts as they are only fixed with thin rubber.
Mine are ok so all good.Have attached photos so please check yours as this could be really dangerous basically no seat belts if you crash.
You can see the belt has not been threaded through metal eye not just the rubber cover. This is at the bottom of the door pillar
The same recall was about on VWs 18 months ago. 1000s of potentially affected vehicles. We saw hundreds through the workshop, not a single one required replacing.
Better to be safe than sorry eh?
Reactions: Tell
The center rear passenger can easily unbuckle the seatbelts of the other 4 in under 2 secs.... Would that be a hazard?? 🤪🤪
I dont know our Arona got sold with the rear seat fault and a tag on it saying dont use untill a fix was found. Clearly on the above a little bit of lost QA in the manufacturing missing out loops not that I could see it from the photo. Ofcourse the company could be done for litigation if after an accident it was found there was a manufacturing fault which they knew about and didnt address.
More cost effective than litigation and reputation damage. Talking of which they disabled the one click close of the panoramic roofs after someone lost their head in America... you might find it on a Google. Easy close of side windows and the panoramic got disabled. Easy close of side windows but excluded the panoramic. Some of our European SeatCupra folk wanted to enable it again... and did 🫣.
My Raval has been called for seatbelt check and managed to get booked in for 22nd December.
Just checked myself and they are fitted correctly as in the photo above but supposed I still have to take it to the garage to be ticked off.
Hopefully they can do a quick visual check when I arrive and not make we wait 3 hours.
Reactions: Tell and Pmac16
